They Sail a Lot Better with the Stick Pointing Up
I think the AYBC standard that the 22 is built to is either 90 or 110 degrees. I've been knocked down to at least 80 degrees in San Francisco Bay. (There is a point in time when you are no longer looking at the clinometer.) However, I did see the boom end drag in the water. (I had blown the mainsheet, but the jibsheet was still sheeted in.) The leward winch went under water and we took around ten gallons of seawater in the cabin (hatch slide was closed and two boards in place). I don't think I had any water back filling the jib. All things considered, the boat righted itself fairly quickly. Some things to note: One, as you go over, speed bleeds off to zero pretty quickly and the wind will push the boat notably to leward. Two, we weren't prepared for the counter roll which almost threw us overboard. And finally, It wasn't that much fun. The cabin looked like it went through the spin cycle, Water went inside the outboard's cover, which rusted the plugs. Rigging definitely was over stressed. (I broke the headstay later that summer.) On a practical note, be prepared to ease the main at the first sign of trouble and vang in to control it's shape when the wind picks up. I think that the boat sails best up to twenty degrees of heel. After that, you're trading speed for thrills.
