Heavy Weather Story- Long Post (Sorry)
N
Nathan
Here's a fun little story: Up here in Buffalo, we had a beautiful fourth of July weekend- sunny and 80 degrees with light winds and little chop. Perfect conditions for a weekend cruising around our home port of Buffalo. My wife, I and my 2 kids: Madeline (3 1/2) and Aidan (1 1/2) jumped into our 26 foot O'Day "Maddie's Cay" and set out Saturday late morning for the Buffalo Yacht Club facilities at Point Abino, a mere 12 or so miles away. We had a great 3 hour sail up and put in for the afternoon/ evening. The day was so much fun that we decided to set out for Port Colborne a small port another 10 or so miles away from Abino at the Erie side of the Welland Canal and less than thirty miles away from or home port at Buffalo. Before leaving, I made sure that I checked the weather report for the return trip on Monday. They were forecasting 20-30 knot winds, but clear with no storms. Sounded like a wild ride home, but I'd been in worse with our boat, which handles very well in heavy weather, providing that you have an appropriate amount of canvas up. I planned on getting up early and setting out before the wind had an opportunity to build up some steam. So we had another great day of sailing followed by an afternoon walking around town. When we got back to the boat, a couple of storms were looming on the horizon and the wind had picked up considerably. We passed a fun evening below deck while the storms raged overhead. When we woke in the morning, we found that the wind had not subsided and was still blowing around 20 with higher gusts. Additionally, we knew that it was likely that the waves had built up considerably through the night. It was at this point that I called up my mother, who lives just outside of Pt. Colborne to pick up the kids while my wife and I brought the boat home. I’ve taken this trip several times solo and knew what to expect in heavy weather. The wind generally blows north-north-east, which puts my destination almost directly downwind, so it’s usually a sleigh-ride all the way in with following seas. You spend most of it surfing down the waves and watching the knot meter run up more than you thought possible. It’s generally a wild ride. So, once the grandparents had the kids, we set out under a reefed main and appx. 90% jib. Coming out of the harbor, we were met with 20 knot wind and eight to ten foot waves. Point Abino sits directly between Pt. Colborne and Buffalo, which requires you to head out onto the lake a considerable distance to clear it with sufficient room under the keel. Given the conditions, I planned to beat into the weather to get appx. 4-5 miles out before turning and heading downwind for the ride home. The alternative was to make a direct course for the deep water marker off of Pt. Abino, which would have had us taking 8-10 foot breakers broadside for the better part of an hour. The fun started 3 miles out, when the furling line snapped and let the whole 155% out in 20+ knot winds. I put my wife on the tiller, slapped on the PFD and headed forward to manually roll the jib back up. It took a while, but by bracing my foot against one side of the pulpit with my back against the other, I was able to brace myself and slowly roll the sail in and secure it as the bow is being dropped into ten foot rollers. Needless to say, I was quite wet when I made it back to the cockpit. We continued with the reefed main alone and managed to maintain almost hull speed and put another eight or so miles under the keel. Meanwhile the waves continued to build to 12-14 footers. We were caught a couple of times by a rogue breaker that laid the boat down a bit, but all in all, it was a fun ride. The color started to come back to my wife’s face and she loosened her grip on the lifelines. Thank god she doesn’t get sea sick. We were rounding the Point, approximately 2 1/2 miles out in 12-14 footers when it hit the fan. A 14 footer grabbed my rudder and sheared off the lower pintle, which attaches my rudder to the transom and I lost steerage. I looked back in absolute horror at my rudder floating up behind the boat and floundering uselessly in the waver. We rounded up and then jibed, which shot the boom across the boat and blew the traveler cart off of its track and into the lake. Nice! So to sum up: no jib, rudder ripped off and the main just blew off the track and was snapping back and forth in the wind. Oh, and I neglected to mention the 12-14 foot waves that were POUNDING our lifeless 26 footer. OK first things first- run forward, drop the main, pull it back in, secure it and lash the sail down. Check. Next- steerage- I fire up the outboard in the hope that it could provide a little bit of stability. Maybe in three footers this would have worked, but in our conditions, forget about it. And to add insult to injury, the floundering rudder drifts into the prop, which gouges half a dozen three inch cuts into it. It just keeps getting better and better. It was at this point that my wife let out the first of many “Call the Coast Guard’s”. I gave it some thought and concluded that: 1. no one was injured. 2. we were not in imminent danger. 3. we had plenty of water below us and room to drift. 4. if I needed to, I had a sea anchor down below that would buy us some time and give us a bit of stability, while I made some repairs. So, I declined and ran below to get some rope. Luckily, it was the pintle that failed and not the gudgeon on the transom, so through a considerable effort, which involved hanging upside-down off of the transom, while being dunked into the oncoming waves, I was able to lash the broken rudder back onto the transom and regain partial steerage. Unfortunately, the jagged edges where the pintle sheared eventually cut through the lines and back over the transom I went to fix it again. It was a fairly iterative process that led to a pile of cut rope strewn about the cockpit, but eventually we limped back into the Pt. Abino basin and tied off. We caught a ride back into Buffalo and headed back to pick up the kids to bring them home. The next day, I picked up a new pair of pintles and a new furling line and headed back after work to make the repairs. I had some marine epoxy to fill the holes in the rudder, replaced the furling line, fixed the traveler system (nothing broke- I just lost the stopper at the end of the track) and installed the new pintles. All in all it took less that an hour and I was headed back home under blue skies, no wind and dead calm seas. I sat on the bow, motoring with the tiller tied off, drinking a beer and reflecting for two and a half hours on the wild day before. Despite the terror, there is definitely something intoxicating about coming through an experience like that intact. BTW- this all happened on a Monday, I fixed the boat on Tuesday, brought her home and we were back at the start line for our Wed. night race and had our strongest finish of the year. Additionally, my wife and kids were back out on the boat for all of last weekend, my wife having put the entire experience behind her. Did I mention that she’s a pretty cool chick? Sorry for the long post, but I thought a few of you could probably relate.
Scooter
Hi, Neighbor
It's like some fox hunts I've been on--I feel so good just having survived them! I can relate to your windy Lake Erie to my third sailing lesson on Lake Ontario a couple of weeks ago. We were out in some heavy winds--not experienced enough to be accurate with knots, but the boat heeled so badly that water was running through it. The instructor shouts for me to lean out and "lock my knees over the gunwale." And I shout, "Are you crazy???" Some good sailors are just not good teachers. I'm glad for the experience, glad I survived it, glad to know what can happen out there in heavy winds; but . . . I don't think a beginner on lesson 3 should be locking his knees over the gunwale. And attempting a "man overboard" rescue in 15-18-knot winds on a third lesson over and over and over again? Well, that wasn't so great, either. Maybe I saved one out of five passengers trying to rescue them under sail. All I can say is that all my passengers, for awhile, anyhow, had better be good, strong swimmers! I plan to practice at Conesus Lake! Scooter
Jul 14, 2004
4
- - Big Bear Lake, CA
Those Great Lakes!
Wow! What a story! If I put my wife through that I'd be looking for a good divorce attorney right now. You made the right decision leaving your kids with their grandparents - we have two small ones as well, and I would have done the same. I grew up in Rochester, so I can relate. Lake Erie has to be the most unforgiving of the Great Lakes. I use to tournament fish for a living in the 90's - before I figured out that being on the road for ten months of the year wasn't helping my marriage - and I've seen that lake turn mean in the blink of an eye. On one occasion, I lost everything on the deck of my boat, (Tackle boxes, rods, a small cooler, my windshield, and two depth finders) coming into small boat harbor I think it was. It was like a scene from A Perfect Storm. Anyway, I spend my days on a small, protected lake in Southern California now. Bad weather here = a cloud blocking the sun for more than ten seconds.
Jun 4, 2004
5
- - Cedar Island
WOW!!!!!
Nathan, you should change your name to John Wayne or Christopher Columbus!!!! I sail a 1979 ODay 25 on Lake Erie and was out that same weekend with my wife and two kids. We were at the western end of the lake at Lemington Marina, near Point Pelee, Canada. We had the same wind, but much smaller waves (6-7 footers). The only boats that left the marina during the highest winds were (3)39+ feeters. They were rail down on beam reachs on their way back to Sndusky Ohio. We waited till later in the day, sailing west into the wind (18-22 knots). Daughter sat on the bow for a 10-12 mile trip, laughing as she got soaked by the waves. The boat handled very well and nothing broke. Hope I never experience what happen to you, but it's good to know the boat can handle it. Only part I don't like about our ODay's is the rudder!!!!
