Heave to
294
Yankee Condore 21 Halifax
Hiee all,
Okie dokie our boat is classified as an ultra light cruiser. I'm wondering how effective it is to heave to with it as it is a swing (fin) keel design. From my reading on the subject they are very finicky as to sail balance. What is a good wind speed to start initially practicing this tactic in?
The boat is a 22 footer 100% jib fractionally rigged tiller steering.
c_witch
Feb 20, 2011
8,062
Only you can say. Your boat will have its own characteristics, and you should learn them in reasonable conditions. Go out and heave to.
Actually having that size jib is GREAT. Why? Because a lot of skippers with 155 jibs can't get their boats to heave to because their jibs are too BIG. We generally suggest they furl them to about 110 to 130 before they heave to.
Give it a try, regardless of what the winds are. The higher the winds the more delicate a balance it will be. Same with lighter winds. Just don't turn too quickly and use the tiller/wheel to assure that the jib gets truly backed, then play the mainsheet and traveler to get the right balance.
It's fun and very, very useful for a whole bunch of things.
Dec 20, 2010
294
Thanx guys,
One article I was reading the diagram showed the boat beam on to the wind with the main sheet let out fully. I'm not sure I'd be comfortable with this arrangement. Other articles have mentioned sheeting in the main so that your pointing into the wind about 45 to 60 degree's. The other point seems to be that properly done one should NOT be making any headway but slipping sideways in the water.
I guess my question about the finickyness has to do with moving about inside our boat and upsetting the trim and therefor having it move out of a hove to state esp. if I happen to be using the head at the time. She's only ~2500# boat with an 8 foot beam (about 7-4 at the waterline).
c_witch
Joe
Jun 1, 2004
8,329
Thanx guys,
c_witch
The method you mentioned with the main is useful for small boats with no headsail.... cat rigged boats, such as lasers, sabots, etc... have no shrouds and no headsail so you must "weathervane" beam on... the sail fills on one side then the other. This method is litterally impossible with swept back shrouds.
I think what everyone here is advising you to do is go out and experiment..... you might be overthinking this, all you are doing is setting up counteracting forces to hold the boat in position.
On a three masted square rigger the foremast topsail is backwinded just as you would with a sloop's jib..... except they would use the gaff rigged "spanker" on the mizzen mast to counter act the backwinded fore topsail rather than the rudder.
You see, every type of rig can be hove to.... you just need to find out with what works best for yours.
BTW, Stu's comment regarding heaving to with a smaller headsail is totally accurate. A smaller headsail will balance against the rudder so you can normally just let the main weathervane..... i.e. stay neutral.
c_witch
You might be right about that. I have a similarly designed boat. The only time I have ever hove to was just to see if I could do it. I did not take a walk about the boat while hove to so I can't say if it would have held its trim. I can say is that I have used sheet to tiller self steering and the boat's course was affected by the crews movement on board.
I think you will just have to go try it out. And after reading this post, I think I need to hove to and then take a walk about my boat as well. Interesting questions. And now I have an excuse to go sailing (like I needed one) :D
chp
Sep 13, 2010
440
Hunter 280 hamilton
I've done it many times on my Mac. About the same weight. I can walk about my boat with very little change. I think the pressure on the sail keeps her steady. One thing I find is you do need some wind to make it work properly. Sometimes I have used the main to help balance the rudder, but again every condition is a bit different. The only way to find out is to try it.
I single hand a lot and when the bathroom break comes around or to grab a wobbely pop I will heave to in strong winds and waves. Boat settles right in and is a pleasure to take a break. The boat just seems to "squat" in the water and becomes pretty stable.
My C22 with a swinger hove to wonderfully, that's the boat on which I learned to do that maneuver. What were the conditions when you tried, or is this one of those "ain't gonna happen" moments? :)
Dec 20, 2010
294
Hiee,
Actually I have not tried this yet, but consider it to be one of those things that any good sailor should know how to do. Kinda like knowing at least 3 of the most valuable knots etc. I have been stuck with sailing within the inlet as the ocean has been rougher then my comfort level or there has been fog onshore. Anyhow the winds tend to be a bit light and often times quite variable as to direction. On top of that the widest part is about 1/2 nm and only about 1 nm in length :(
c_witch
shnool
Aug 10, 2012
556
WD Schock Wavelength 24 Wallenpaupack
I can't get my 25 to stop sailing while trying to heave to. We attempted it several times in 15mph winds, and I was making 1 knot forward while attempting it. If I eased the main any more , we'd get pushed around.
I find it easier to just lash the tiller spill the genny, and ease the main while pinching. It'll flog the genny, but if you drop the genny shortly thereafter it should sail along nicely with a bubble in the main, at a very slow pace.
...and I was making 1 knot forward while attempting it.
You will always be doing that when hove to. people sometimes misinterpret what it means. You do NOT stop. The boat does keep moving.
Mar 1, 2012
2,182
Depends on the boat. Had a Prindle 18 that would just park when hove too. Had a long keel, attached rudder 1960's era CCA boat that would do the same. My longish keel 21 footer forereaches at about 1/2 knot.
So it depends.Also depends on what size head sail you have up. The last two I mentioned would heave too beautifully with a working jib- not so well with a genoa.
Jul 5, 2010
161
Oday 22, Mariner, Challenger 15 Michigan
My O-Day 22(shoal keel with centerboard) heaves to very well. It feels lilke it's sitting on its trailer in the parking lot (winds around 25 mph with 3' waves). My other two boats (centerboard) don't heave to as well and never really settle down.
Oct 10, 2009
1,108
Beneteau 393 Muskegon
My boat takes a little while to settle down- it will do a little dance, rounding up, then falling off as I play the genoa sheet and the rudder to get the right balance. Mostly, I let the mainsail vane in the wind, but I have sheeted it in just a tad to keep it from flogging. Once the boat settles down, it bobs along nicely to leeward.
Macgregor 21 Clinton, NJ
C_witch, the fractional rig with only a 100% jib could make the boat very finicky even trying to heave to. My V21 is a masthead rig but with a smallish jib(probably belonged to a 19-footer) and I've never been able to get it to settle down for more than a few seconds when attempting to heave to.
Sep 16, 2011
346
Venture 17 Hollywood,FL
We had our V17 hove to nicely the other day in 10-15 kts. She pokes along at around 1 kt. Enough to easily get in to swim, we needed a line in the water though to hang on to.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
I sail a San Juan 23 which has a small weighted stub keel with a centerboard housed inside. With my std. jib and the full main she heaves to nicely. I have a topping lift that is run through sheeves and to a line stopper. It allows easy adjustment of the boom from level to about 2 feet higher at the rear of the boom. By raising the boom this way it is very easy to find the hove-to sweet spot.
Ray
Ray
