Has any of you C30 owners set up a day tank to gravity feed a heater? I have the Dickinson Newport diesel and am thinking about running the high pressure fuel pump to it to prevent the pump running every now and again.
Where did you put your tank? Above the dresser? Above the settee? My heater is installed on the starboard bulkhead. What pump did you use? Did you install a thru-deck filler?
Thanks!
-Patrick
Thanks!
-Patrick
