Have used
a heat gun to help a friend strip the bottom paint and barrier coat off a CS 30. The barrier coat was Interlux 2000 I believe andthe anti fouling was for sure VC 17. It worked very well, we used 1.5-2" putty knives with the corners rounded slightly. You do indeed have to be carefull but starting from far away and working slowly closer until just the coatings soften then movingthe knife and the gun ahead in unison slowly worked very well. The job didnt take that long- probably about 10 man hours or less as I remember, and wasnt bad for being messy.That said, I tried the same method when I redid my rudder a couple of years ago- the barrier coat was VC tar under vc 17- it didnt work well and I ended up grinding it offI believe I heard 3M has a new coarse but very sharp and non loading sanding disk that works very well for stripping like this. Messy tho.
