steven f.
Looking for advise in regards to the heat exchanger on my Westerbeke 21. It is a 1985 engine with 1300 hours on it. Though I am the third owner it has been very well maintained. My engine has been overheating this winter and I noticed the exaust isn't spitting out as much water is it should. I checked the sea strainer, replaced the raw water impeller and its still overheating (and not spitting out enough water through the exaust). I started checking to see where the breakdown was and found that water is getting to the heat exchanger (all the lines are clear and water flows freely to it with the engine off). With the engine running there isn't enough water going from the exchanger to the exaust pipe(it doesn't seem to be as much as it should). Are my worst fears true, do I need to replace the heat exchanger or is there a way to clean them out. What about rebuilt heat exchangers, is there such a thing and if so are they worth it? Any and all advise welcome on this chapter in my book of boating adventure.
