heat exchanger
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
What did you replace your 201027 Universal heat exchanger with.
Where, how much and part number ?
paulj
:troll:
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
I recall I used
Universal Part #299835
I did pay about 400 and it is the HX with the straps not the brackets that are welded on. FWIW the original had the welded on brackets.
DaveJ
Apr 2, 2013
526
This would be a good time to replace any hoses associated with the HX, once you have the HX out you may find chafing on them. I installed new hoses and protected them with a section of automotive heater hose wherever the hose contacted the engine. I cut the heater hose into 3-4" pieces then slit the hose lengthwise and slipped it over the coolant hoses, securing them with tyraps. Have a look at the exhaust hose also, mine needed replacing but I would not have noticed with the HX in the way.
paulj
Mar 16, 2007
1,361
Ray
Thanks for looking.
Pulled and serviced Heat Exchanger.........every thing OK.
My HE had clamp on brackets.
Heard thru the grapevine you where no longer a CIA operative.
paulj :troll:
