John V.
I found my Universal M-25 in my C-36 to be too hot running at anyhting more than about 2000 RPM, and after going over everything, decided to exchange the original 2" dia. heat exchanger for a new 3" unit. About $350 later from Hansen Marine (superb service), I swapped in the new one, changing all the hoses in the process. After filling w/ coolant, the engien would heat very qucikly to over 200 degrees. I kept shutting down and trying again to bleed the system, and only after finally running with the fresh water pump to thermostat housign hose disconnected, could I get all the air out. Things then settled down to the thermostat temperature regardless of engine speed or load. The question is - How does one easily bleed the air from a C-36 installed M25??? (Also, how does one easily and neatly drain one for work?)Thanks!jv
