I need to replace the headstay on my 1985 H23, but don't have the original. It has a Kenyon mast, chainplates on the catwalks, and was delivered in July of 85. I wasn't entirely sure how to interpret the "Turnbuckle to Tee Ball" on MrUnix's rigging page.
I measured one of the lowers, and found that the dimension matched the "Turnbuckle to Marine Eye" length of 13' 3 1/2" if I measured the overall dimension with the turnbuckle fully extended to the cotter pin eye.
Would I interpret the headstay dimension the same way? Some of the rigging houses use the dimensions from the bearing surface of the T-ball and the center of the pin to the chainplate, with the turnbuckle 1/3 extended.
Unless I can find the original dimensions, I'll probably end up getting Norseman or StaLock fittings and making it while I put the mast up, but that can get exciting. If anyone has any dimensions and where they apply, that would be great
- Jim
H23 'Good Stuff'
- Jim
H23 'Good Stuff'
