Check out the Cruising Design furler, if you are not racing, and are on a budget, they make a fine system, that can be self installed. I have a larger model than would fit your 28 but mine has been working fine for 16 years. I call that a good value.Good luck!
I think this system is the best I've seen: check out Spin-Tec in the chandlery here. When you factor in all the parts you'll really need for installation its hundreds less and has far fewer moving parts to break. Please excuse the commercial, but I really like this system.
