Headliner Caps
Deb
Hi all, thanks for reading my inquiry and any feedback you can supply. My traveler is mounted by the companionway and the underneath screw holes land in the forward section of the aft cabin. There were headliner caps to cover the holes but 4 of them have gone missing. Any ideas where I might find replacements??? Thanks again.
Ariel
Feb 1, 2006
279
Pearson 36-2 Houston, TX / Rock Hall, MD
Deb, You can get the plastic plugs at most hardware stores like Ace, HD and Lowes. You will find them in the drawers in the hardware section. They come in various sizes from about 3/8 inch, up to about 2 inch. Either measure the hole or take one with you if you still have one. Dave s/v ARIEL
Ariel
Feb 1, 2006
279
Headliner Caps continued...
Deb, I forgot to mention that the plugs (or caps) that I have found only come in black and white. But not to worry, Almond appliance paint is an almost exact match to the liner color used by Pearson. Just buy a small bottle of touch up paint and paint the plugs. Dave s/v ARIEL
Deb
Kind thanks!
Thank you Dave! Will check out HD, etc. Your insight on coloring was most helpful too... will likely replace all for conformity and should not look bad at all (just not original). Happy sails to you on s/v Ariel! s/v Deb on Air
