Vector Analysis
Okay, lets think about this a little…you are flying along at a 20 degrees heel and the "Back-of-the-neck" tiny hairs tell you that the limit of comfort has been reached. All the books and "Sunfish" experience says turn into the wind, but as you do…the crew starts scrambling for the high side yelling comments about life, seamanship, and your parents martial state at the time of your birth. Been there, done that!What has happen can be explained with an excruciatingly painful class in vector analysis, but… The centerline of the boat is at 20 degrees; the top of water is horizontal (hopefully), so the rudder is at 20 degrees to the top of the water. You move the tiller (probably with a with a wee bit of anxiety) to turn the boat into the wind. This turns the rudder, which up until that moment was experiencing a nice equal flow of water on both sides. Now, the flow on one side slows down and the flow on the other has to speed up. Since we all understand (yeah, right!) how sails and wind work, we have something like "lift" on the rudder. This "Lift" works to turn the boat, but since it is at a 20-degree angle to the top of the water it also works to lift the bow and change the line of the boat. This refigures you righting harm (did you know you had one?) and the boat heels over a tad more. Okay, depending on the anxiety of effort on the tiller one may experience a warning of an eminent underwear change.My Hunter 22, "MoonDancer," has proven to be a typically 1980ish Hunter, in that it lists a bit to starboard and heels with the lightest winds. Having said so, she has many times forgiven my miscalculations in seamanship and delivered me home safe and…dry. As for those days with the occasionally gusty moment and the "Comfort Factor" of yourself or those onboard is two-blocked, try un-cleating the main sheet and adjusting as the wind blows. If the "occasionally gusty moment" is more than occasional, then reefing the sails is definitely in order. These solutions may not be the most efficient (as in heart thumping) styles of sailing, but it allows your crew to unclench the gunwales and let blood back into their white knuckles. This does much for a happy day…
