head
3
Hunter 33 Deltaville, Va
I pumped fresh water into the head from the pick up end to get out a bad smell, now there is no suction for water to be pumped in. Anyone have same type of problem, should I use one of the replacement part kits, I need to replace the joker valve also.
Dec 2, 1997
9,011
- - LIttle Rock
Need more info
What is the make/model/age of your toilet?
I'm not quite sure what you did...can you explain in detail exactly how you "pumped fresh water into the toilet from the pickup end?" Till I know, I can't tell you whether the toilet needs any parts or not. If it's a Jabsco I wouldn't put ANY money into it...the kit costs as much as new toilet!.
If you'll search the Head Mistress forum for "intake odor" you'll find a lot of discussion the describes a simple inexpensive permanent cure.
Sep 27, 2010
3
Re: Need more info
thank you for your comment, I am going to replace the head it is a Jabsco
Dec 2, 1997
9,011
- - LIttle Rock
Check this out before buying another Jabsco..
You can upgrade to a Raritan PHII or PHC , which has been rated the top manual toilet in its class for decades, for very little more $$ than a new Jabsco.
sbo.com PHII PHC LBA A lot of people here have bought the "upgrade" and they ALL recommend it.
However, you may not need a new toilet, or even any parts for it...so let's make sure before you spend any hard earned money for a new one!
