Head and Holding Tank Suggestions
Kurt, This is the address for the "Holding Tank Eye" which is an inexpensive, very easy to install, and somewhat accurate guage that will show you when you have 3" or less left in your holding tank.http://www.49er.aqua.net.au/2bfa2872.htm Something else to consider is using fresh water to flush the head.I used this set up for using the head sink to flush with fresh water to avoid the stench of dead or dying enclosed sea water that sometimes smells worse than the stuff being flushed. Used 2 T joints and a valve between the sink drain and the head intake. Picture an H with the horizontal part of the H being the valve/connector/diverter of the fresh water to be used for flushing. Much better smelling head as long as I can afford the fresh water which is 99% of the time. I also used the same setup on my c28 successfully. Enjoy your new c310.Stan"Christy Leigh"c320 #656
