Head tank issue
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
My 1985 Nassau 34 needed new head hoses. Open any cabinet where they transversed and the smell was prominent. Last spring I concluded it was easier to install an entirely new system using the under V berth area for my new tank and so I ran my new, high end, hoses only a few feet to the new tank as the head was located next to the V berth. The old tank was/is back under the cockpit - a pretty good run from the bow. I removed all the hoses that ran through lockers and solidly plugged up the stubs that were left from the old tank - except for the pumpout which I left as it was. My intention was to remove the old tank, which would have to be cut out in sections due to its location - not a pleasant proposition. I was, at the time, leaving on a 1300 mile trip and as time ran out, I decided to just leave the old tank in with the lines suitably plugged. It posed no problem for the trip and is still, nearly a year later, doing fine. The old tank is situated in such a way as its removal would not give me much additional storage. I am considering just leaving it in place indefinately leaving the stubs of the old hoses plugged. I now have access to free pumpout so I could flush the old tank out repeatedly to reduce the odor if I were to cut it out. I am considering throwing bleach into it and letting that sit. My question is would the bleach eat at the plastic tank and/or the hose stubs. I am also considering just forgetting about the old tank and going about my life.
Dec 2, 1997
9,011
- - LIttle Rock
As long as the tank isn't causing any issues...
Remove the hose stubs, pumpout hose, and all the thread-barb hose fittings and put threaded plugs (available from any hardware store) in the tank fittings and leave it there.
F
Fred
Pretty cheeky to add to Peggy's
advice, but here goes. I would rinse the tank, since you have a free pumpout, with bleach, head dedoriser, or vinegar, then let it dry completely, maybe a vacuum on the pump out and the other holes open, or just laeave all the holes open in good weather. Then plug the holes with pipe plugs.
