response
Do not do anything to the forestay. It slips into the extrusion. You will have to measure the forestay per instructions and cut to length. When you put the mast up, make sure the top black plastic head cap will clear the mast. If it doesn't, then take a couple of inches off and repeat.The only other thing is when you uncoil the extrusion coming out of the box, make sure you have several folks to help you so when bending it back into a circle, it will not get loose and hit you.
