Head sink hose replacement recommendations
Aug 17, 2013
1,339
Pearson P30 202 Ottawa
Hello all!
we are working on replacing the head countertop, wood and laminate, after looking at the drain hose it appears to be very old, I was thinking about replacing it at the same time I remove the sink.
What kind of hoses do you all recommend?
Jun 21, 2004
3,212
Beneteau 343 Slidell, LA
I recently replaced the 1 1/2” galley & lavoratory drain hoses with Raritan saniflex hose. The OEM hoses that I replaced were 20 year old Trident (#102) hoses. The Trident hoses showed no signs of deterioration internally or externally. I only replaced them because I was replacing thru hull, valves& tailpieces and I wanted the entire assembly to be new. Saniflex or Trident hoses is essentially “bullet proof” & more than suitable for the drains.
