Dennis Stone
Just bought the boat in May and finding out how much I dont know. Went sailing this past week end and had a problem with the Jib. The Harken furler did not unwind all the way. When I tried to correct problem I found that the Jib Halyard had come off the cleat and the Jib had droped down about a foot. Tried to pull up, no luck and then tried to pull down and same problem. I'm guessing that the steel wire has jamed in the roller at the top of the mast. Somebody please tell me it isn't so???I had never taken the Jib down after the PO put it up during the survey. I dont know how long this may have been going on.Second issue is that one of the PO installed the bow pulpit. The Jib appears to rub this (i.e. it is lower than the rail). Is there a mod or is the jib suppose to be all the way up or what?HelpFrom a newbe on the block.Dennis Stone#764 SRFK
