Randy
Just recently removed my aluminum holding tank and replaced with polyethelene. Replaced all hoses with the exception of the vent line. The head flushes OK but as the bowl is cleared the very last portion seems to have some pressure behind it and is propelled above the rim. There is no pressure at all on the pumping mechanism. The only thing I altered when changing out the holding tank was to remove part of the vented loop on the vent line. This was necessary because the vent line would not reach the fitting on the new holding tank. Did I screw something up? I would have replaced the vent line but could not find a replacement locally.
