Head portlight Replacement
Robert
My S2 9.2A ia in need of a replacement head portlight. Does anyone know of a replacement? Best Regards Robert
G
Greg
I just replaced mine with a Beckson. I would look a little harder next time for a exact replacement as the Beckson required a lot of custom work to make it fit since the S2 bolts don't line up with the port. Since the bolts are practically embedded in the boat I wound up making a spacer to bolt onto the existing bolts, then I could screw the new port into the spacer. Pain in the butt.
Robert
Update! The S2 9.2A portlight is a 4x14x1" portlight made by Beckson. I could not find it in the catalog however a call to Beckson solved this problem. I found Matt at customer service to be very helpful on this topic and now have a replacement portlight on the way to my boat! Robert
