C
Chris
I had plumbing problems last year on my O'Day 30 and am trying to fix them as economically as possible for this season. I've been reading and learning a lot from the forums here and would like any to know of any problems opinions/improvements etc with my plans - thank you in advance!!My Raritan Compact head had a broken cam and plastic lever when I took it apart which certainly lead to some of the troubles. After many discussions with Raritan - to fix a vacuum problem - I'm going to replace the pump with a PHII pump that fits the Compact base and solves the vacuum problem with its air vent. This isn't really known - it upgrades the Compact to a PHII. While I've got the system apart - the hoses need replacing also - I was going to change the configuration also. I've removed the Y valve that sent the waste to either the tank or overboard and plan on piping it to the tank direct. From the tank there is a T that so you could pump out the tank from the deck fitting or use a manual pump to overboard to another seacock. I plan to simplify the system - go right from the head to the tank and then have the option to pump out of go overboard. Cap off the other seacock.Here are what I think are the issues/questions:I recently read that I should have a valve on the discharge end of the tank (discharge is on the bottom of the tank- don't think I can change the tank around) to keep waste out of the hoses --- makes sense and I should have thought of it .....does anyone know of a Y valve that can positively act as a stop valve - known position to stop waste? I don't think I have the space for a stop and Y valve - if I use only a stop valve - is it okay to use a T and split the line coming out of the tank to go to the pump out fitting on the deck and to the manual pump ---it was piped that way before and "seemed" to work okay.Replacing the hoses....is PVC with 45's an alternate to the recommended $8/ft white sanitaton hose? For the pump out line (longest of all) - can I get away with a lesser quality hose? While I want to do it right - I also don't want to break the bank. I assume that the other sanitation hoses work or people wouldn't buy them ....maybe??Thanks for your help.....
