Head Lube
G
Gail Moorehead
I have been unable to find the head lube that you recommend. I believe it is Sealand Head Lube. I have used both Sea-Lube and Headlube and both provide a short term fix. I want to removew the punp and lube correctly. Thanks
Peggie Hall/Head Mistress
SeaLube or SuperLube...
Neither is made by SeaLand...both are available at most boat stores...both are thick teflon grease which properly used (take the toilet apart and slather the innards with it) should last at least a full season, if not two. Neither is something you can just pour down the toilet, so whatever you've been using that's only givng you short-term results, it's not SuperLube or SeaLube. Btw...fall is the best time to lube the toilet. The grease protects the seals and valves from drying out over the winter.
