Head Leak
17
2 30 palmetto fl
I have a Catalina 30, and over the weekend I was cleaning the bilge. The water in the bilge was tinted blue, and since I had recently added a blue scented head cleaner to the toilet bowl, this indicated to me that the head was leaking. Any suggestions on where I should start looking?
Jan 1, 2008
89
Islander 36 Salem MA
Well now your in a s$#%Y spot . I would start at the head and work your way to a leak ,inspecting everything as you go . The blue dye will help with this . The c 30 system is easily accessible ,good luck
The two most obvious places
are the hoses themselves or the hose clamps at the connection. With the blue stuff still in (or add more) use a white rag to find the leak.
