Sandi
PeggyAfter following your advice, we cleaned out the intake hose to our manual head. The creek we are in doesn't move much - the smell is the same whether inside or outside the boat. After we are out of the marina for a couple of flushes - the smell no longer is there. We removed the intake hose from the thru-hull and flushed it well with fresh water. The thru-hull is not clogged in anyway - tested that too. Put the hose back on and then left for a couple of weeks. When we returned, no smell. However, when we re-opened the thru-hull we were not able to get any water to the bowl. We opened the vented loop and poured fresh water in, but it still wouldn't pump water thru. We double checked the vented loop and the diaphram was properly replaced. What do we need to do to prime the intake hose? Thanks
