David Popken
I have a 78 H30 that came my way with a self contained all plastic head w/integral holding tank (3gal). The pump finally gave out and I want to replace this unit with a standard manual head and holding tank. The original head was plumbed to a 1 1/2" thru hull for discharge, with a tee connection to a pump out fitting on deck. There is no inlet thru hull. I do have a 1 1/2" thru hull for the lavatory drain that is below the waterline. Could I use this thru hull for intake and then plumb the lavatory drain into the head, thus eliminating the need for another hole in my boat?
