L
Lysle
Is there anyone out there who has had to remove their head holding tank in a Catalina 27 (76 dinette set up, dinette settees and table to starboard, galley to port amidships? Holding tank is under the forward dinette settee.) It looks like mine will have to be removed to repair a leak or be replaced. It also looks like it may or may not be able to be removed without cutting the settee. The tank is definitely longer and wider than the opening but it appears it is just slightly shorter. Any advice/help, or info I should be aware of before starting this task would be greatly appreciated.Thanks,Lysle
