Head and A/C winterization
Richard
I tried to winterize the head and A/C but could not get the hoses off. Any suggestions or alternatives? Thank you
7,684
Alden 50 Sarasota, Florida
two critical boat tools
Either of the following is a critical boat tool and will make this job easy - hair dryer or heat gun set on low.
Dec 2, 1997
9,011
- - LIttle Rock
In case you need just a LITTLE more instruction
Warming the hoses with a blow dryer (use a heat gun only IF you know what you're doing with one) makes 'em a lot easier to get off. Also makes 'em a lot easier to put back on.
Bill O'D
A/C
Find the high side of the A/C hose opening and simply pour pink into it to permeate the water within.
