Hello,
I have a 1979 Hunter 27 and the inside of it is very, very damp. I cannot stop the moisture, and I have tried everything from an electric dehumidifier, to damp raid buckets, to those stick on wall dehumidifiers that absorb water from the air like a sponge. All them pull moisture of out the air and fill themselves with water, but moisture still exists in the boat, specifically on the roof of the cabin where excessive condensation forms visible water droplets. I'm at my wits end with this problem and I think that installing vents on my topside hatches will fix this problem. Does this sound like a good idea? The problem is at its worst when the boat is warmer on the inside than the air on the outside; so I figure that with vents I can equalize the temperature on the inside of the boat and stop the condensation. I'm also betting that the increased air flow will help decrease moisture levels. So if anyone has tried this, I would really appreciate your advice on the matter, and some good places to get hatch vents.
Thanks for your help,
