Fairly simple, just be patient
AndyMy co-owner and I did both hatches about a year ago, with no major troubles. But if we had it to do over again, here is what we learned:1) Be patient. The old sealant won't give you much grief. Just scrape or grind it off once the hatch is out. 2) We had to grind out some extra room for the new hatch because the new one was a bit bigger. Be patient here too, 'cause we ended up grinding out a bit too much and I had to go in later and add some Marine Tex to the corners to make it seal properly.3) After the hole was the right size, we sealed up the core that was now exposed by the grinding, with Marine Tex white. Be sure to check the fit of the new hatch carefully after you have the hole cut and edges sealed up. We found that where the newly ground out opening was too big, there wasn't enough bite on the screws to fasten the hatch to the deck. So we had to build up those areas with epoxy before we could drill the screw holes. And I recommend pilot holes for all the screws to avoid cracking.4) We used 3M 4000 UV caulking but a polysulfide should work well too. The trick here is to mask off the deck around where the new hatch will go, and leave enough room inside the masking tape to do a beveled edge to your caulking bead. In other words, leave some room between the hatch and the masking tape to smooth down the outer edge of the caulk bead. Put on a good solid covering of caulk all around the hatch flange. Then place it on the opening, and gently screw the screws down till they are just about tight (maybe 5/8s of the total length of the screw for example. Do this all around the hatch, and then smooth the caulking out and remove the masking tape. Now, let it sit for a day to allow the caulking to firm up under the hatch flange (by the way, mask off inside the boat too in case it oozes in). 5) Come back the next day and gently tighten the screws all around. Don't overtighten!! You may find that the caulking bead edge doesn't change, which is fine. It has changed inside where you can't see it. If necessary, touch up the bead of caulk around the edge, and that should do it!Good luck, it'll be great.Take care,Ron and Tom
