table solution
My husband and I had the same table issue. The table was so heavy, I could barely slide it up the mast pole to the 2nd hole that holds the table to the ceiling. But, we hesitated to cut the table down because we needed the sleeping space for our two kids. I worked up my nerve and cut approximately 10 inches off the wide side of the table. Then I used the "curved" edge from that piece as a template for the final cut taking a total of about 14 inches off. Also using the same template, I made a board from pressed wood that spands the gap between the new cut edge of the table and the V-berth. There is a slight overlap of the board onto the table, but it works great. (I keep the section of board directly under the berth cushions).I re-used the plastic edge piece after routing a new channel on the wide end of table.The last modification was two cup holders added to the table near the center at the wide end. I cut two 4 inch holes and put in the same cup holders as used on the stern rail seats. No more cups-a-flying!The smaller table has improved access to the cabin seating and the V-berth. It is much easier to manage. Husband and I are happy with the result.
