Has anyone installed a fuel or water level gauge on h34
Jan 24, 2017
671
Hunter 34 Toms River Nj
I have noticed newer boats have fuel and water gauges and was looking into adding one. I can't find anything on you tube. I see that they make lots of after market gauges however I don't know of anyone who has installed them.
It looks like a fairly easy dyi project.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
I have not Capt, but all they are is a voltage loop / series circuit. The big issue you will have to discover is whether you have an opening in your tank top to mount the sensor, usually a 6 screw configuration approximately 3" diameter to match the sensor flange.
Jan 24, 2017
671
Thanks, still looking at my options. Still a little hesitant to do this myself, however don't want to pay the boat yards extortion price.
Oct 29, 2016
1,929
Completely understand, from what I have seen each sensor will have (3) wires, +, - and a signal wire, depending on how many tanks you want to monitor. Water tank #1, Water Tank #2, Waste tank, Fuel tank is usually on the motor control board in the cockpit.
If you go here
http://www.marlow-hunter.com/wp-content/themes/marlowhunter/export/Wiring-Schematics/
you will get an idea of what is needed, appears all wiring is 16 ga marine type wiring.
Jan 24, 2017
671
Thanks,
Garnet gauge looks to me the best way to go. No drilling looks to me to be the easiest install. Looks like I can get multiple sensors to plug into one display. Going to talk to one of there reps today.
Thanks again for the link.
Robbie
Sep 25, 2008
1,096
CS 30 Toronto
All the sensors in 1 wire. Each sensor has a unique "address" so they can send their own code to the display. For really tall tank you can stack 2 sensors together.
