Has anyone ever replaced a Yanmar fuel pump with a
pethia
Jul 3, 2004
27
- - cape cod , MA
generic auto electric fuel pump? I have an SB8 Yanmar single lunger. If you have used an electric type, what psi/gpm/gph did you use?
Don
Fuel Pump
Not a Yanmar, but a 14hp Universal. A 2.5psi pump from NAPA should do the trick. About $35.
Another Story
pethia Try the link to the message board on the C34 website. It includes the Napa part # from a link on that thread. Stu
Jun 3, 2004
347
Hunter 30_74-83 Lake Lanier, GA
Pethia,
If you convert to an electric pump, make a blanking plate for the old mechanical pump. Remove the mech pump and run the hose directly to the filter housing. The mechanical pump has check valves and a rubber diaphram that can fail anyway. If the diaphram fails, your crank case fills with diesel and you can get a runaway engine. A new lift pump is only about $65.00 and will last 10+ years Pat McCartin Inland Marine Diesel Buford, GA
pethia
Jul 3, 2004
27
- - cape cod , MA
Pat, would you recommend replacing the
original yanmar mechanical or going with the generic electric available at NAPA?
Jun 3, 2004
347
Either way....
I like the original, partly because of my relationship with Yanmar. Either way it will work, the idea is to supply low pressure fuel thru the filter to the high pressure injector pump. I could see a surveyer in the future having a fit over a non "original" adaptaion. Pat McCartin Inland Marine Diesel Buford, GA
