Give the oil a rest, and you a beer
Using an oil extractor makes changing oil a breeze, with a few caveats; first, let the engine warm up if cold, and let it cool down if hot. My rule of thumb is to get all the items together for the oil change after the engine has been shut off. This will usually take about a beer, after which the oil in the sump is usually cool enough to not melt hoses and warm enough to be withdrawn easily. I don't have a good answer for the bits of melted hose in the sump, but if it were my engine, I'd be straining to learn how to remove the oil pan. A new, untried possibility is to cut a piece of the old hose and place it into a pan of motor oil that's being heated to a known temperature. Learn what happens as the oil temp exceeds boiling point while you're stirring the mixture continuously. If it dissolves, you want, no...you need to get the plastic away from the bearings.Good luck!
