Trailer Sailor Cruiser
Tom, Thomson asserts that ungrounded mast are hit in the same proportion as grounded based on his offering of reports from surveyors. He concludes that mast without a LPS system are ungrounded and those with are grounded. He then offers that more ungrounded mast are hit than are grounded. This is flawed logic because he does not account for the very strong possibilities for other reasons the mast would be grounded. Electrical lighting, instruements and antennas may in fact and probably do ground the mast on all boats equipped with an inboard. Its very likely that many if not most of the boats in his study were inboards which would mean that most of the boats shared the same quality of a grounded mast. His comparison is flawed and his conclusion is flawed and the tens of writers that lean on his flawed logic are echoing the same flaw.If we concluded that inboards have grounded mast and boats without auxilliaries have ungrounded, Boat US insurance claim numbers would suggest ungrounded mast are hit in one third the ratio of grounded mast. This is the single best statistic available that I know of. On my survey so far, of the 12 mast hits, 9 were grounded or should be considered grounded because they listed both an inboard and antenna on the mast. 3 were ungrounded. Grounded mast then were hit three times the rate of ungrounded. This figure matches identically the Boat US statistic.Certainly my study has no statistical basis yet... My goal was to get at least 100 reports before even considering it of worth.Half of my reports were of near misses and of those, twice as many near misses occured on ungrounded compared to grounded. Again... to few to draw conclusions... but if prelimary results hold, they may tell a story.There is no doubt that an adequate ground will mitigate damage if a strike happens. The word mitigate is interesting and hence the reason why I think if my chances of being struck are reduced by staying ungrounded, that it might be as good as a decision as providing what would be a half hearted attempt at grounding which might increase the liklihood of a strike. Again... the best evidence to me so far is that ungrounding does help the percentages.Saying this, I do think a lot of sailors think if they don't have an intentional lightning protection system, that they are ungrounded... this is not true. While far too simplistic, if you have an inboard, your probably grounded. I agree that your suggestions to add the salt water and others were pertinent and appreciated your input. btw...I did add the salt water question to the survey. My goal was to keep the survey limited to ten questions. I felt that near strikes deserved some attention because if there is a ratio disparity between near strikes... then that may tell us something about the mast ground / unground issue. Its true that my comments are driven by the fact that I'm a trailer sailor but I'm also a cruiser. Last year I wetted my hulls twice, once for a weekend overnight with the grandkids on the local lake and once for twenty four days of cruising on the Great Lakes which covered 800 miles and included two open water 90 mile crossings of Lake Huron and two 36 mile crossings between Michigan's lower peninsula an the North Channel. I am not hesitant about open water passages though I watch the weather window because my boat is a trailer sailor and thus subject to coastal cruising. Coastal defined by restricted to a weather window which most think to be 24-36 hours.You are right that my concern is relative to the mast ground / unground issue. If a mast is grounded and I'd assume that all will be on inboard equipped boats, then a LPS system is in order to provide an adequate conductive ground.My argument is somewhat a tangent issue where the prime issue for most is how to ground adequately. I really have not intended to weigh in on that other than to wholeheartedly agree to do it on boats that have grounded mast.quote: Let me add a twist to that, would you want your loved ones down below in the cabin when that lightning followed down the mast into the cabin looking for a place to exit and your boat wasn't bonded? Not me. I respect that... The problem is this, I sail on fresh water. The experts seem to be saying that to provide an adequate ground, I'd likely have to copper plate the majority of my wetted surface... unrealistic. And if an inadequate ground is more risky than remaining ungrounded... then I will take the risk. I could choose to not go sailing... but then I'd suffer a life without something I truly love to do. I could choose to do what most trailer sailors do and not cruise... but again, I don't much care for day sailing anymore... I love cruising. I can't afford a blue water boat and am landlocked any way... but a trailer sailor works for me.There are a fair number of trailer cruisers like me... should we try to emulate our blue water cousins or recognize our differences and make decisions according to our needs. I've heard the query tens of times, should I drop jumper cables into the water from my shrouds from people who think that they would feel better if they were doing something. I've not heard of one instance that jumper cables attracted a strike... so don't think it has proven to hurt and if it offers assurance... then well and fine. The big issue here is that out there running around are folks like Thomson who are purporting that I'm liable if I don't do something because he wants to make a living as an expert witness and has propelled himself to expert status with flawed logic. I'm simply saying that for blue water boats... if y'all want to consider yourself liable because you haven't provided a certified ground system... thats fine. But, I can see where that will go. Trailer sailors will get caught in the trap unless someone steps up to the plate and says... wait a minutes, ungrounded mast are different. Staying ungrounded may be just as or more prudent as trying to ground where it can't reasonably be done.Thomson has clearly said, that he considers an ungrounded mast to be a liability issue. I don't agree. In part because his logic is flawed. In part because the few good statistics we have are telling us otherwise. Just as you want to make the right decisions for your family on your blue water boat, I so to want to make the right decisions for mine on my trailer cruiser.I suffered a lightning strike in my ham shack.... a huge fireball exploded right above the console and burned my eye lashes. It happened shortly after installing a lightning rod (aka veritcal antenna) on top of my tower. Everything was disconnected. The tower was well grounded, the ham shack was grounded. Experts said, don't put a vertical (lightning rod) back on top and I've not been hit since. In twenty years, the only time the tower was hit...was shortly after installing the vertical and this story is repeated over and over again in the ham community.I suffered a near miss on my sailboat on an open water passage out of sight of land. The shock wave shook the boat it was so close. Experts say that the shock wave only travels a short distance of perhaps 40-60 ft. It was the only strike heard. Ten miles is the accepted distance for hearing thunder so it was the only strike in a twenty mile diameter and it hit 50 ft from the boat yet didn't hit the mast or boat....why not? Sorry, I gotta believe if I were grounded... it would have hit the mast.I hear what yor saying about the unpredictability and there certainly have been times when a shorter mast is hit in a marina with taller mast around. There might be explanations, there might not. I'm an advocate of gathering as much data about these kinds of strikes as possilbe. I think they would tell a story and in my opinion it would be a story about percentages rather than hard rules.
