One thing I have not seen here yet was the use of any type brain efficiency external regenerating system (beers). Sometimes when I have a tough problem a couple doses and things magically become simple. Warning: results may vary.
I only meant through the one wall.Through-bolting through the spar is generally a bad idea unless you can get a compression post on the bolt inside the spar. It is far too easy to over-tighten the nut and damage the spar as a result.
mmm, that's for plastic rivets, won't corrode, but...How about this thing, I have no air compressor:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97757
