hard to adjust sheet & boom
Jul 8, 2011
49
Catalina 30Mk III Oyster Bay
I've got a 1992 Cat 30 with mid-boom sheeting. The boom seems to be more difficult to move than I would suppose. I've replaced the main sheet and checked the blocks which all appear to spin easily.
I'm used to end-boom sheeting (had a C&C 35 with no problems) which is fast and easy but the mid-boom seems hard to adjust without winching - any suggestions? thanks
What purchase do you have available on the traveler car control lines? Many of us have upgraded the cars to the 6:1 from Garhauer.
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
I also bought the Garhauer 6:1 traveler and use it all the time. Best addition to the boat. Continuous traveler line long enough to come back to the helm. I also didn't like the way the main sheet was set up with it eventually going through a clutch to the winch. I replaced that system with a triple ratchet block with cam cleat attached directly to the traveler. I used the existing 3 blocks on the boom. There is less friction and with a long enough main sheet I run it back to the helm. Works much better for me.
mortyd
Dec 11, 2004
952
Catalina 30 easy living
i'm missing stu's reference to the traveler, but my switch to garhauer blocks and line on my mainsheet made a big positive difference. old blocks can seem sorta ok until you switch to ball bearing ones.
