jim
the deisel on my catalina 30 takes longer to start than I'd like. i hold the glow plug for 20 to 30 seconds and then crank for no more than 10 seconds. my understanding is that cranking for longer periods will overheat the starter. when it doesn't start, i repeat the process. it generally takes about 3 repeats to get it running.once runing, it works well. after it has run for a while, (such as going out onto the lake then shut off for a couple hours sailing, it will start again quikly) there is not smoke and it seems to run good, good oil pressure and takes it up to hull speed nicely, even against weather.fuel filters are new this year, but i was wondering about the glow plugs. the boat is a 1985. i am not sure about the hours on engine cause the tack was wired wrong before i got it and showed much higher rpms that actual. how do you test the glow plugs? are they the same as automotive glow plugs? any tips on where to purchase? jim
