I have an additional idea for you to incorporate with this Hermit. When you make the top, put some "coamings" around it and when you make the supports for it out of the tubular stainless that I suspect you will use, you can collect the rain water to replinish your fresh water supply with.
I saw someone that had made a hard top doger and done this and had some directional valving to alllow a flush with first, and then he will collect the water and it works like a charm. I was just thinking about the fact that you seem to like better mouse traps :dance: and I had seen someone that had set up a slick arrangement like this and thought that I'd share it with you
