Hard bottom over antifouling
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I am hauling in another week and going to usehard bottom over my antifouling paint with a special primer so says the boat yard so has any body done this.
My diver is super cleaner and spends over hour some times 2 hours so my paint is wearing sooner and switching to Blue Water hard bottom paint.
Wish me luck.
Nick
Good luck Nick
In our cool climate / waters I had yard put Pettit Trinidad over a soft ablative painted by a previous owner. Boat in water 365 nights. Diver says paint is holding up.
Prep included pressure water wash down, sanding of old paint to create solid surface, dry out, then 2 coats of PT.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
What John said. You need to get down to a firm surface or the hard paint may slough off with old ablative.
1,440
Achilles SD-130 Alameda, CA
Yes, you can use a hard paint over an ablative. It's all in the preparation. It is a fallacy to claim otherwise.
BTW- It's all anti fouling paint, whether it's hard, ablative or otherwise.
Jun 25, 2004
1,109
I have found that some solvent based paints can’t be put over some water based paints. For example, you can’t apply micron 66 (solvent) over Hydrocoat. (Water based). We sanded the old Hydrcoat off before applying the Micron 66.
If you don’t know what kind of paint is on the boat, you can apply a test patch of the new paint over the old, following the manufacturers instructions that you can find online.
Feb 26, 2011
1,440
Yes, the paints must be chemically compatible with each other.
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
And Bond to each other.
It is always the surface preparation that counts!
Many paints require their "Primer" to bond.
That is the KEY!
Jim...
PS: I spent 25 years working with ALL paint manufactures.:pimp:
What does the paint manufacturer say? They should know their products.
A really good hard pressure wash will get rid of much of old ablative paint.
1,109
Unfortunately, using a power washer to remove anti-fouling paint pollutes because the waste water drains into the local water table or system (unless there is a filter in a catch basin system to remove it). We used a sander and a fine-particle-filter in a shop vacuum to collect the dust, which we disposed of responsibly.
Our marina has a catch basin.
Even better than a shop vac with filter is a Dust Deputy. Most of the dust is collected in the bucket with the remaining collected in a bag in the shop vac. And any fine particles are trapped in the HEPA filter.
http://www.sv-secondstar.net/stuff-we-like/14-dust-deputy
Likes: DrJudyB
Everett is a "Clean Water Port" in Washington. All boats are power washed by the Marina upon hoist.
Likes: DrJudyB
Jun 25, 2004
1,109
John,
What are you going to do when the ban in Washington on copper AF paint starts on Jan 1 2020?
JamesG161
Feb 14, 2014
8,105
Granted, I sail in shark free unsalted water, however, I've been using a copper free paint for a couple of years with good results. I do get some green stuff that washes off easily when wet or brushes off after it is dry. But no zebra mussels. The paint is Blue Water Marine Shelter Island. It did get good reviews on PS a few years ago, which is why I changed over. Also less expensive than the usual Interlux/Petit brands. Not paying for the marketing.
They'll have to kill me and pry the copper from my cold dead hands.....
Likes: JamesG161
Besides, If you make a run up into BC you can empty your holding tank a long the way and the sea will wash it back into the Seattle slough that comes from the failing Seattle sewer system.
Got to love Washington. They get my boat money just because I choose to sail there.
