Many small sailboat engines are adapted from larger ship lifeboat engines. (Lister, Volvo, Petter, Yanmar)
They were mandated as handcrank start as an emergency feature.
I had an old Yanmar YSE back in the day and the location (deep in the engine bay) meant that is was impossible to handcrank start. I extended the hand crank shaft and made an A frame prop to support it and thereafter could handcrank start it. The secret is to be able to handcrank and release the de-compressor without missing a beat or dropping revs.
My present boat also has this model engine and the front fits under the stairway so the handcrank is easily accessible.
I rigged a lanyard (control line) from the de-compressor lever back to a turning block, ( the lever needs to be pulled astern) then forward to a hand made cleat. This is a very simple setup.
Control line released
Control line tensioned. De-compressor engaged
Control line in cleat. De-compressor engaged
Starting process.
Throttle set to starting position. Engage and cleat off control line.
Handcrank engine to get oil and fuel into the cylinder. Don't skimp on this step.
Put your back into it!
Crank up to speed with right hand and flip control line out of cleat and away we go. Hopefully.
With a 2 or 3 cylinder engine you will need 2 or 3 lines.
The engine should start on one cylinder and then you can engage the other cylinders.
This how a large ship engine is started.
gary
Starting process.
gary
