Hand rails on coach top y/n?
Jimski
May 20, 2015
44
Catalina 30 Seabrook
My boat is a Catalina 30, but my question is more generic. The C-30 has teak hand rails on coach top. Mine are pretty weathered and the port side is held together with epoxy. My crew sometimes complain the rails are not much help and uncomfortable to sit on. Another C-30 on my dock removed the rails and repainted the deck, and installed a small stainless hand hold forward. Looks great.
Opinions, please. There's lots of things to grab onto besides these teak rails. I am thinking of removing them. But honestly I am nearly always in the cockpit so I don't know. How useful are those rails?
For me as handholds they're useful but not critical. As footholds however I really like having something there. I can't really picture trying to work at the mast or boom on a heeling bouncing deck without having that insurance policy against sliding feet.
Likes: DaveJ
May 24, 2004
7,209
CC 30 South Florida
Never found anything more reliable that cabin top hand rails in good working order. "One hand for the ship and one hand for yourself" I guess it depends on the type of sailing but if you are out in deep swells and have to go up front you will wish you had them. Davidasailor26 gives an excellent example, when standing on the cabin top a sailor is above the lifelines. A place to interlock your foot can be most valuable.
Likes: Rich Stidger
Feb 10, 2004
4,228
Hunter 40.5 Warwick, RI
I use my cabin top hand rails all the time in any sea state other than dead calm. I would not remove them. However they are not comfortable for sitting. Put a square boat cushion on top if you want to sit.
Gunni
Mar 16, 2010
5,937
You have the option to replace the wood handrails with stainless steel. CatalinaDirect sells them I believe. Keep your cabin-top handrails.
Likes: Tom J
Ward H
Nov 7, 2011
3,827
My 93 C30 has the stainless hand rails on the cabin top. I believe newer C30s also have them. Should be easy to swap out your teak for SS.
I agree with the others, I wouldn't remove them unless replacing them.
Nov 8, 2010
11,386
OK, this is in the racing forum. So.
Why is crew sitting there????? On the cabin top?
Crew should not sit there. It does no good. Adds zero righting moment. Have them sit on the deck, legs over the side. And put the handrails back on.
Jimski
May 20, 2015
44
Thank you everybody for you opinions. Your arguments are sound; the rails will stay unless I replace them with stainless.
For the racer comment, spot on. I move crew around to get the boat heel to be 15-20 degrees. There are times that means putting everybody on the low side, or at at least not on the rail.
