thanks for the vote of confidence Bob.......as far as the hand/grab rail is concerned they are about 13'- 6" long and about 11/16's inch thick by about 2 and 1/4 inch wide ...with a round edge on one side and a chamfered edge on the other side cut to about a 60 degree angle...they are made out of teak....it is possible for him to get the teak in that dimension maybe from a wood supplier in Mami Fl or Teak East in Donald's SC ...dont know what the freight will be but his best bet is to call the suppler in Mami and drive over there and pick it up if they have that length in stock....i will try to get to my boat some time today and get accurate dimensions and post them here...it is gloomy and rainy here today....Man, if I were in your situation I don't know what I would do. With the cost of a piece of teak that big so utterly ridiculous I might be tempted to go stainless somehow. At least I wouldn't have to maintain it anymore, but I think it would detract from the looks of the boat. I think I would them probably default to a composite product and hit it with a router to get a profile that was close. I would stick to the original stainless tube stand-offs to keep the look the same. Woody is our best woodworker/cabinet maker. I hope he chimes in on this one.
yes i did and it took me about 3 hrs shiming and thighting and checking and re shimming and so on till i got it correct all the way around the shaft..... this is tough work if you dont have a helper on the inside of the hull tighting and loosing the bolts...lots of climbing in and out ...but what they hay it was a good cardio work out lolI made some progress today, but it was kinda likethree steps forward, two steps back....
first problem was I could only get 1100 rpms. 1.5 -2 knts over ground. (i had my sails stowed)
then I was dragging my dinghy, and the bow shackle broke...
I was 2+ hrs behind the high tide I needed...
finally got the boat hauled and the bottom was pretty clean for not being painted in 7years. yes, the prop was fouled more then the bottom paint.
but, the strut is cracked/broken. a small fingernail clipping is missing on the prop side....
woody, can you please pm the contact info for the mfg of the strut and ballpark price that you paid and when???? i sent you the info in an email
ive seen some publications on replacing struts, bu2 dont they need to be alined during installation?? yes they do no two are ever the same so be ready to do that
did you do the work or have someone do it for you... how many hours did it take???
