Your 710, ham email and more...
T:Your 710 is a widely used, relatively powerful (150W) Marine SSB. Airmail (the 'client' software on your own laptop) was originally written by Jim Corenman with the 710 and 706 SSB's in mind and you'll find your radio quite compatible with the ham (the actual name is Winlink) system. I'd encourage you to visit www.airmail2000.com and download the Airmail software, install it (easily done) and begin looking it over, as there are several learning curves to climb and one of them is understanding how to get the most from the Winlink system by using Airmail effectively. (Don't overlook downloading Jim's Getfax and Viewfax software, as well; you'll find them very helpful for capturing wx fax products via your 710. All this is software is free due to Jim's selfless efforts and Airmail is elegant, simple and robust. The propagation prediction software helps you determine which bands to use for which distances at any given point in the day/night, it is much larger to download, and getting it when having access to broadband is recommended...but it too is free.IMO the best part about Winlink is not its email functionality but rather the huge catalog of wx f'cast products, all real-time and of digital quality when received, that are available to you 24/7. The availability of this info has increased safety aboard offshore boats in ways GPS never could.You will need a TNC (the 'radio modem' that makes an analog SSB work with a digital laptop) and a cable designed specifically to connect to your 710; you might visit Farallon Electronics at www.yachtwire.com to price the 2 basic TNC choices. They can also sell you the cable, as can HF Radio (www.hfradio.com). Offshore, I find it helpful to have the automatic PTC II-type TNC (no tuning of the radio required; the computer does it automatically) but it is more expensive.T, which nets you use will depend a lot on where you are. There are many listings of SSB Nets available on the web, probably all of them not quite uptodate; one that was updated not too long ago can be found at www.cruiser.co.za/radionet.aspSince you'll initially be cruising in the Caribbean, you might find the summary I wrote up on Caribbean WX F'cast info to be of help; you'll find it at www.southwindssailing.com/articles/0205/weathernet.html altho' please keep in mind that it was written in 2001-2002 and surely some info has now changed. You'll note that some of the wx nets also pass yacht traffic and provide other services...and include both Marine SSB and ham frequencies.Hope this helps, good luck on installing the rest of your (ham email) system, and on your coming cruising plans.Jack N3FYP
