Anyone know the Manufacturer of the stoppers installed on the early 2000's? I had a problem where the stopper would not lock open and let the halyard run unless someone held the handle down to ease the line. The fix may be obvious to some, but I will post here for those (like me) who may not known. If you tighten up the hex bolt that the handle pivots on, you can adjust the tension which hold the clutch open. For the interior ones you will have to pull it to get to the bolts, but the exterior ones can be adjusted in place.
