Halyard shackle options
33
Cal Jensen 1977 Cal 2-27 La Marianas Sailing Club
I had the shackle on my mainsail bust on us during our last sail. Time to replace it. What are the pros and cons of the various halyard shackles? Can you just use a simple D shackle? I'd prefer simple and strong over everything else.
Here's a few questions for the experts:
Does a halyard shackle need to have a swivel?
Do you have to use a twisted shackle for the jib if you don't use a swivel?
Are swiveling snap shackles worth the extra money?
Is it all just a matter of personal preference, and any shackle with the proper load rating will suffice?
Ross
Jun 15, 2004
14,693
probably not politically correct but I use screw pin shackles on my halyards.
jimg
Jun 5, 2004
175
catalina 27 dana point
I've used a knot for somewhere over 30 years now. They never break, rust, jam, require tools to undo, and they take up less space and weigh less than any shackle. Just sayin".
Catalina 320 Dana Point
Joe
Jun 1, 2004
8,323
No
No
If you need a quick release and you change the headsails often.... yes...
for a mainsail... no
yes... and ... yes.
For replacing your mainshail halyard a capitive pin, D shackle is fine....I wouldn't spend a hundred bucks on it without knowing what my own personal preferance is... My main halyard is a wire to rope... with a thimble... so I choose the forged, keypin with bar shackle so it won't accidently separate from the thimble.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
The last 2 boats I've owned have the D shackles, but once I didn't get the pin seated properly and it let go, requiring someone to go up the mast and get the halyard. Those pin-style shackles look like they'd be a little more work to connect, but more secure.
druid
Nov 8, 2009
33
Thanks everyone.
I had thought about just tying it on, but the headboard has some pretty hard edges and I'd be worried about the line wearing through.
Joe - Have you ever had problems with those keypin shackles accidentally opening? That thumb lever looks convenient but also looks vulnerable.
Four, Stu, and Ross - The eye splice on the halyard is still intact. Can you squeeze an existing splice onto that molded piece or does it have to be threaded at the time of the splice?
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
the wichard one I use has detents that make it tough to open without a shackle wrench or pair of pliers, I have no concerns about it opening on it's own.
I had mine spliced on the halyard when I replaced the old halyards this spring. unless your eye splice is loose, it wouldn't fit onto the shackle. The plastic bushing is designed to be spliced into the line tight so it doesn't slip off. I'd suggest the line be respliced on the new shackle.
