Dave
From time to time I have had the problem of going to raise the main and find that the halyard has "jumped the pulley" and jammed. This makes for a bad day since the mailsail will not raise. To date, the solution was to sent the lightest crew member "up the mast" to put it back on the sheave. Not so easy when you don't have light weight crew members. If others have had this problem, please let me know you solved it. Is there some type of "keeper" to insert over the sheave to keep it in its track? I will contact Catalina to get their answer, but would appreciate input from anyone that may have had and solved this problem....DAVE S/V Lyric
