OK, I need to shorten the "fat" part of my jib halyard where the eye splice is inside the outer jacket. The supplier sent it with an eye that is about 1 in long, plus the tail goes about another 3 in, maybe 3.5, inside the outer jacket. The H23 has a rather narrow metal fitting that supports the jib sheave, and the splice jams in that fitting (I can see the "clamp" marks on the line) just about where the splice starts. I have been experiencing some furler jamming since I got this new halyard, I think because the halyard cannot be hauled in enough due to that jamming- the shackle can't be hauled in closer than about 4 in toward the sheave opening.
I suppose I could cut the eye off and re-splice, but I don't have a fid and am not sure how short the spliced part can safely be. And while I have spliced 3-strand, no experience with braided.
The other option is to cut off the splice and use a halyard hitch - but I am not sure if this is as safe as (or nearly so) the spliced eye. I am thinking of tying to the shackle using the halyard hitch and temporarily leaving the eye on the end - yeah, it'll be ugly with that 5 in or so hanging off the side, but at least I can test it that way. Seems to me the depth of the hitch knot is maybe 3 times the diam of the line, say a bit over an inch, which would let the halyard get tighter than with the current eye. Since it is pretty easy to lower the jib on the furler, I can always cut off the end with the eye later, assuming it works. I do have a hot knife.
Does anyone have any experience doing this and should the halyard hitch be safe enough?
Peter I
Peter I
