A
Arturo DeVitalis
The shaft going through the center of the two plastic pulleys that redirect the halyards to the starboard blocks...that shaft has broken flush at the inner forward part of the of the shaft leaving the two pulleys dangling and wobbling from the rear part of the shaft that is still firmly positioned. It appears that the shaft was a one piece shaft that is pressed or frictioned fit into the body of the boat. If this is so, then how can it be replaced, or if not replaced, what other options do I have? I need so help here!!!
