Hallberg rassy mistral fuel tank
2
The fuel tank is beneath the cockpit floor with no access from above. My issue is the fuel gauge apparatus and how to change as well as the difficulty in fueling with the fuel port on the transom. Anyone install an inspection plate on the cockpit floor for access to the meter or allow a dip stick; changed the fueling port to on deck aft port?
p4620
Dec 8, 2012
2
Hallberg Mistral 33 Manchester
Yes, well we all have these surprises when we buy an old boat. There is no easy answer to the fuel gauge matter. As noted earlier I am in the process of taking the engine out and expect to be able to reach the tank and replace the sender, which is shorting out, I like you idea of a access hole in the cockpit floor. Positioning it will be a challange.
