While motoring back after a romping sail (7 kts in 2 - 4 ft swells) in our 1978 Crown 34, running the 2QM15 at about 21-2200 rpm when suddenly the rpm dropped to about 1500 and we started belching black smoke. I looked down and the throttle lever was in the same position.
I throttled back to idle, all seemed normal and the smoking stopped. I gradually ran it back to cruising rpm. No problem, provided I wanted to provide a smoke screen for a platoon of Navy commandos.
So back it off to where it stops smoking and we putter back to the dock at 3 kts.
Today, my mechanic came out. She fired up just fine, we let her warm up a bit. He pulled the throttle cable pin at the engine end and put it into forward gear. He climbed down into the cabin and open the throttle wide open. NO SMOKE...
But we did find that the mixing elbow was cracked in a few places. He attempted to pull just the elbow but had to pull the exhaust manifold as well because the elbow was just too stubborn to remove.
The hose end of the elbow was bit blocked, maybe 25-30%. He thought maybe the rough sailing had loosened some carbon which eventually blocked the elbow and was held in place while we were still running. Once the engine down on Sunday, it was loose enough that it came out when the engine was re-started by the mechanic.
In any event, I haven't got the manifold and elbow back but am curious about if and then how I would go about de-carboning the engine without tearing it down. The mechanic didn't feel the amount of carbon in exhaust port in the head was too bad.
Any thoughts from the interweb mechanics?
